Date/Time: Thu, 02 May 2024 23:15:40 +0000
Bracket orders with Parent and Child at the same time
View Count: 1939
[2013-04-10 15:32:05] |
User14731 - Posts: 15 |
Hi, Is it possible to submit a bracket order and have the parent and child orders sent to my trading service at the same time, rather then having the parent execute first? My account is with Interactive Brokers. Thanks |
[2013-04-10 17:03:46] |
No, this is not supported.
[2013-04-16 22:49:25] |
I'm sure you guys are busy with more complex requests, but this would be a nice feature to have. Sending the entire bracket order with a stop that moves to break even after certain amount of price movement would be great. I can do this via TWS, but it's not as smooth. This way users on laptops could be more mobile and have TWS handle the order on IB's end. Thanks for your help. |
