Date/Time: Mon, 29 Apr 2024 00:20:15 +0000
How do I get up to 2 years worth of minute data of Cl?
View Count: 1129
[2013-11-27 03:43:07] |
Greentea - Posts: 26 |
Can only get minute data from current date to Sept 1/13. Historical server set to Sierra Chart server.
[2013-11-29 03:24:27] |
We recommend using the Sierra Chart Historical Data service: http://www.sierrachart.com/index.php?l=doc/SierraChartHistoricalData.html And using the Continuous Futures Contract feature: http://www.sierrachart.com/index.php?l=doc/doc_ContinuousFuturesContractCharts.html You may want to setup a separate copy of Sierra Chart for this: http://www.sierrachart.com/index.php?l=doc/MultipleServices.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
