Date/Time: Sun, 08 Nov 2026 11:14:33 +0000
[User Discussion] - How to reset Global Graphics settings to default
View Count: 2838
| [2019-05-29 14:29:39] |
| Katrina R Machado - Posts: 1 |
Started messing with the graphics configuration before I had an idea of what I was doing. Is there a way to put it back the way it was originally? How did I miss this in the docs?
| [2019-05-30 04:58:36] |
Refer to this page: Resetting Sierra Chart to a Default State / Restoring Backup Global Configuration File Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
