Date/Time: Sun, 05 May 2024 02:50:39 +0000
Daily and weekly bars With Pullback Numbers
View Count: 1370
[2013-11-26 21:27:31] |
Moti - Posts: 63 |
Hello SC team, Recently you added the "High&Low Pullback Ask/Bid Vol Diff" numbers (SG37&SG38 ) to the Study " Number Bars Calculated Values" a very useful number With the New SC Data feed: Did the Pullback numbers will work correctly online on a Daily / Weekly Candlestick or OHLC bar on Futures index and commodities? Thank you, Moti Date Time Of Last Edit: 2013-11-26 21:28:40
[2013-11-26 22:53:30] |
The pullback calculations will only work properly with Intraday charts. And symbols that provide bid and ask data.
