Date/Time: Sun, 19 May 2024 06:52:28 +0000
Market Deth level settings
View Count: 1360
[2019-05-27 23:27:45] |
WarriorTrader - Posts: 245 |
Hello, In SC 1729 I could go to Trade -> Chart DOME Settings and set the "Max Bid/Ask Depth" to 3 to limit the market depth levels to 3. After upgrading to 1919 this option no longer works. I am getting all market depth levels. Using CQG WebAPI. Thanks, WT |
[2019-05-28 09:45:27] |
That setting no longer exists. You need to use this particular Chart Setting instead: Chart Settings: Maximum Market Depth Levels (Chart >> Chart Settings >> Market Depth menu) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-05-28 09:46:17
