Date/Time: Sat, 18 May 2024 23:29:58 +0000
[Programming Help] - Referencing A Range of Data
View Count: 906
[2019-05-27 13:04:02] |
User871277 - Posts: 34 |
I did set up certain Backround on Alert studies with isolated events. Now I want to combine them. For that I did add another Backround on Alert study and I try to use "Referencing A Range of Data" like AVERAGE(C[0:-100]) < 100. Works fine as long I adress studies directly. But I want to scan back if in a certain amount of time the previos defined events on the CBOAC studies did occur. F.e. one CBOAC is C<Lower Bollinger and another one price crossing back into lower Bollinger. Both work singular and return 1. I want to now create an CBOAC which scans back the last 30 Bars if those to CBOAC studies did return 1. It seems not to be possible. |
[2019-05-27 17:05:37] |
User657944 - Posts: 173 |
Hi register to this forum and take a look to a study called Subgraph shift reference, then you will probably set up but I think can help you on what you wants to do: http://forum.obchodni-indikatory.cz/forum/ke-sta%C5%BEen%C3%AD My 2 cents Alberto Date Time Of Last Edit: 2019-05-27 17:05:59
[2019-05-27 17:45:05] |
Did register. Hopefully someone let's me in :) |
