Date/Time: Sun, 28 Apr 2024 06:58:51 +0000
Custom value at Y color issue on 1924 release
View Count: 697
[2019-05-26 08:54:44] |
@sstfrederik - Posts: 403 |
Hi SC, A client reported a color issue when using Custom Value at Y for SG that use secondary colors. Just fired of the SC study: "Ask Volume Bid Volume Difference Text" it has the same issue. The issue is apparent when you load the study. Can you have a look and fix it. edit: "custom value at Y with border" - drawstyle works fine by the way. Thanks, Frederik Date Time Of Last Edit: 2019-05-26 09:49:29
[2019-05-27 02:15:57] |
This will be resolved in the next release coming out today. The reason this occurred is that it is now supported to activate the secondary color setting and use that to control the background color of this Draw Style. But that should not occur when using the Data Color array or when using Auto Coloring.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-05-27 02:18:31
