Date/Time: Mon, 06 May 2024 13:17:51 +0000
Question regarding DOM/Chart DOM order entry and cancelation
View Count: 1212
[2019-05-25 16:34:33] |
lw - Posts: 11 |
Hello, i have two questions please, 1) on a DOM or Chart Dom i can place an order at price X multiple times and i end up with multiple orders at that price. Is it possible to disable the multiple orders at the same price feature? I only want one order or none at a certain price level. 2) is it possible to cancel an order directly in the buy/sell column of the DOM? I know i can click the X in the chart window (Chart DOM) or in the order column of the normal DOM, but trading order flow this is sometimes too slow and i have to shift my focus from the tape to the chart or order column in the DOM. Ideally it would be possible to have (1) and (2) together. Is such a config possible with SC? thank you! |
[2019-05-26 03:14:40] |
1. It is not possible to do what you want. Instead just modify the order quantity up rather than placing a new order. 2. No but you can align the X button towards the right: Chart Trading and the Chart DOM: Change Location of Orders and Position Lines on Chart Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-05-26 03:14:59
[2019-05-26 17:05:12] |
lw - Posts: 11 |
Hello, thank you for your answer. Regarding 1) The point is not to change order size but rather have at most one order at a price level or none. I want to prevent having multiple orders at a price level. This has nothing to do with size. 2) I already found that but still the problem remains, that workflow is sometimes too slow, focusing to hit the X and taking the eyes of the tape. Anyway, thanks again for your answer. May i suggest this behaviour as a feature request? with kind rgards |
