Date/Time: Thu, 02 May 2024 02:18:54 +0000
UDP RELEASE_DLL Windows error code 10035
View Count: 876
[2019-05-24 20:07:27] |
User796776 - Posts: 95 |
When using the UDP interface RELEASE_DLL--[DLLPathAndFileName] the following entries are posted to the log: Unloading DLL C:\SierraChart\Data\PSLib_debug_64.dll | 2019-05-24 15:47:21.014 UDPListener (1500). Port 22904 | Error with UDP message peek. Message was not processed. Windows error code 10035: A non-blocking socket operation could not be completed immediately. | 2019-05-24 15:47:21.860 * Loading DLL C:\SierraChart\Data\PSLib_debug_64.dll | 2019-05-24 15:47:22.030 As a result the script is unable to update the DLL as it is being used by another process. I had been using the UDP interface successfully in the past, but now cannot solve this issue. |
[2019-05-26 03:01:26] |
Not really sure about this. That is quite unusual. We have not heard of this before. Make sure that command is sent as a single UDP datagram.
[2019-05-26 08:31:39] |
binaryduke - Posts: 360 |
I have been experiencing the exact same issue since v1915 when using the methods described in this thread: ACSIL: Example build script using udp commands to unload / load dlls Date Time Of Last Edit: 2019-05-26 08:32:57
[2019-05-26 21:31:14] |
The command is sent as a a single datagram. Based on binaryduke's post, I decided to roll back and test. I was able to successfully use the UDP interface and overwrite the DLL with v1864. For v1865 and up, after calling the UDP interface, the dll remains in use and I am unable to overwrite it. |
[2019-05-26 22:37:01] |
Ok we will do some testing and see what the problem is. We do see some work being done in recent months with this area of the program and we will see why this is happening.
[2019-06-07 18:36:08] |
Tested with v1931, the UDPListener error is no longer present in the log: Unloading DLL C:\SierraChart\Data\PSLib_debug_64.dll | 2019-06-06 11:09:40.416 Loading DLL C:\SierraChart\Data\PSLib_debug_64.dll | 2019-06-06 11:09:41.809 However, the lock on the DLL is still in place. Need to close SC to update the DLL. |
[2019-06-07 18:37:58] |
Can you tell us the UDP command you used in this particular case.
[2019-06-07 18:43:17] |
RELEASE_DLL--C:\SierraChart\Data\PSLib_debug_64.DLL
[2019-06-09 02:59:28] |
We cannot reproduce a problem with this. Once the DLL is unloaded it stays unloaded.
[2019-06-09 15:16:48] |
Sorry, I may have not been clear. The issue is that SC keeps the DLL file open after calling the UDP interface and the Unload message appears in the SC log. Repro: 1. Create a powershell script, UnloadDLL.ps1: $client = new-object net.sockets.udpclient(0) $peerIP = "127.0.0.1" $peerPort = "22904" $send = [text.encoding]::ascii.getbytes("RELEASE_DLL--PSLib_debug_64.DLL") [void] $client.send($send, $send.length, $peerIP, $peerPort) $client.close() 2. Run script: powershell -executionPolicy bypass -file .\UnloadDLL.ps1 3. SC log message is written: Unloading DLL C:\SierraChart\Data\PSLib_debug_64.dll 4. Open windows explorer and delete C:\SierraChart\Data\PSLib_debug_64.DLL A File In Use Dialog is presented: The action can't be completed because the file is open in SierraChart_64.exe. Therefore, I am not able to replace the DLL without exiting SC. |
[2019-06-09 15:27:08] |
Yes. I am experiencing the same issue described in post #10.
[2019-06-10 02:09:23] |
We definitely cannot reproduce what is shown in post #10 using that exact script. The DLL unloaded and did not load again and we could successfully delete it. We tested on version 1932.
[2019-06-11 21:03:36] |
One thing we want to add is make sure you specify the complete path and filename when releasing a DLL.
