Date/Time: Thu, 02 May 2024 13:56:03 +0000
Automatically Update All Charts' Symbol Settings to New Service
View Count: 2190
[2019-05-24 00:07:06] |
User379468 - Posts: 508 |
How can I automatically update all charts' symbol settings from one service to another without manually updating each chart window, in each chartbook?
[2019-05-24 15:31:52] |
bradh - Posts: 854 |
You can use Edit>>Translate Symbols to Current Service, a recently added feature. You will probably need to do it on every chart, but it is easier than opening chart settings and doing it there. |
[2019-05-26 16:45:58] |
It does all charts at once.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-05-26 16:46:35
[2019-05-28 18:42:30] |
That's excellent! When I tried it, it didn't work for some reason. I was previously using CTS symbols, and connected to CQG login now (no real-time, only historical), and selected that feature but the symbols did not update.
[2019-06-02 04:06:40] |
Ok if you are still having a problem just confirm the symbols are correct. Refer to: https://www.sierrachart.com/index.php?page=doc/helpdetails1.php#Symbols And if you are still having an issue after that, contact your broker for help because clearly your account is not authorized for the real-time data. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-06-02 04:07:54
[2019-06-21 20:40:59] |
Can this be set to automatically all symbols in watch lists also?
[2019-06-24 00:46:28] |
We will make sure the Associated Watch List for the chart is supported when using Edit>>Translate Symbols to Current Service.
[2019-06-25 04:56:39] |
Can you also enable auto-rollover of expired symbols in the Associated Watch Lists?
[2019-06-25 05:20:33] |
This is already supported. The command for it is under the Symbols menu of the Associated Watch List window.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-06-25 05:20:43
