Date/Time: Sat, 18 May 2024 18:25:50 +0000
Sierra Data Feed
View Count: 554
[2019-05-23 23:17:06] |
User965825 - Posts: 15 |
Hi, I´m sim trading on the DOM and currently using Data from CQG. It is horrible, because the data is lagging during live trading, not mentioning the replay mode. I read one of your comments, where you mentioned that trading with data feed from Sierra works better. Could you please tell me what do I need except for the Service Package 5? I just need data for the e mini S&P. Regards |
[2019-05-23 23:55:41] |
We don't normally hear about lagging data with CQG. You potentially could still have the same problem with the Sierra Chart Exchange Data Feed. But we recommend giving it a try. It will only cost 5 dollars for a trial and you can also control the number of market depth levels with it to manage the bandwidth usage. The instructions for it are on this page along with pricing information: Sierra Chart Exchange Data Feed Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-05-23 23:56:00
