Date/Time: Sat, 18 May 2024 23:12:11 +0000
Chart view shifts when study is added, removed, or hidden
View Count: 578
[2019-05-23 20:29:35] |
EdCarp - Posts: 25 |
When a study is added, removed, or hidden, the entire chart view will shift up or down, but it's not consistent. It's very annoying to have a study applied to a chart, only to have to dismiss the study window to drag the chart view back to where it can be seen, then bring up the studies window again to make any changes. Is there a chart setting or something that can stop the chart from jumping when a study is applied or changed? Please remember that this behavior isn't consistent - it only happens about half the time. |
[2019-05-28 12:17:03] |
The behavior is 100% correct based upon the Scale Settings and any Interactive Scale adjustments you have made to that particular Chart Region. Most likely the solution you would want is described here: Chart Scale and Scale Adjusting: Basing Scale Only on Price Bars Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-05-28 12:17:21
