Date/Time: Sat, 18 May 2024 21:37:29 +0000
Switching from CQG to SC Order Routing + Data
View Count: 1112
[2019-05-23 16:29:54] |
KXRCap - Posts: 52 |
Dear SC - I am getting a run around from AMP on the costs associated with SC and moving from CQG. So, currently: SC Plan w/Mkt Depth = $25/month CQG Trade = $.20/rt CME Data Non-Pro Full = $15/month If I switch out of CQG to SCOR+Data, if I am reading your stuff right it is the same $.20/rt order routing fee... Does anything else change? Extra TT Platform fee? Thank you. |
[2019-05-23 22:58:28] |
In your particular case at the present time you have to pay $30 a month for the data feed since you are using Sierra Chart through AMP. Otherwise, everything else is as you list and there is no TT platform fee. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-05-23 22:58:54
