Date/Time: Sat, 18 May 2024 15:56:46 +0000
CQG Fix Connection w/AMP
View Count: 577
[2019-05-23 15:37:07] |
SierraFan - Posts: 84 |
Sierra, Can you help? I'm using Sierra 1919 and yesterday I was disconnected 3 times. Today I've been disconnected 1 time, so far. I've only been on this CQG connection since the beginning of this week. Before that I was on the CTS Fix since I started using Sierra and I cant remember any disconnects. Is CQG having an issue?
[2019-05-23 20:18:40] |
With respect to CQG disconnects, refer to the following information: CQG Trading Platform Service: Frequent Server Disconnections when Using CQG Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
