Date/Time: Fri, 03 May 2024 07:00:11 +0000
Trade | Show Orders and Positions
View Count: 1542
[2019-05-23 00:26:26] |
cmb999 - Posts: 211 |
menu item cannot be unchecked, build 1919
[2019-05-23 01:24:24] |
Nothing has changed with this. We do not understand what this is about.
[2019-05-23 02:37:52] |
i mean i cannot hide the order lines from the chart when i click on that menu item, it blinks, but the order lines still show as a different example, Show Order Fills hides and unhides the fills as expected |
[2019-05-23 03:06:15] |
This is because you have Chart Trade Mode enabled, the documentation does explain this.
[2019-05-23 04:24:30] |
that explains it, but i am struggling to locate how to set the width of those order lines, so that they are not the entire width of the chart . .
[2019-05-23 21:52:08] |
We believe the following setting is what you are looking for: Chart Settings: Trade Drawings Left Align % (Chart >> Chart Settings >> Trading menu) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-09-15 02:15:12] |
User400196 - Posts: 2 |
Hi there, I have a similar question but with a slight nuance — I have two charts of the same symbol next to each other. My goal is to have both charts active to trade on using keyboard shortcuts but I only want one of the charts to display my current orders. When I un-check the option to display orders and current positions it blinks on the chart but remains unchanged. Is there any other way to accomplish this?
[2020-09-15 04:30:46] |
There is no way to do this if you also want to be able to trade from the chart.
[2020-11-06 04:13:38] |
NCooley - Posts: 20 |
Hi there. so when I have "show orders and position" on HIGHER timeframes ... the amounts are huge. any idea what setting that is? thanks http://www.sierrachart.com/image.php?Image=1604638251930.png http://www.sierrachart.com/image.php?Image=1604638308256.png Date Time Of Last Edit: 2020-11-06 13:38:19
[2020-11-06 13:39:06] |
We do not know what you are referring to in regards to "huge". Your Sierra Chart account which you have logged into this Support Board with is expired. So we know what Sierra Chart account you are using, go to Help >> Support Board from within the Sierra Chart desktop program and then post in this thread telling us this is done. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
