Date/Time: Tue, 28 May 2024 17:13:36 +0000
DTC Protocol Server
View Count: 658
[2019-05-22 17:10:53] |
User138602 - Posts: 169 |
Greetings, I would like to run 2 main/source instances: 1 for LMAX (+3 sub instances)and 1 for Rithmic (+1 sub instance). I am running into the problem of not being able to download data due to "symbol not found error". Depending on what Source Instance i start first, the sub instance(s) of the 2nd source instance connect to the first source instance. Can someone pls give me the link to the corresponding setup_page to get this working? Regards, Date Time Of Last Edit: 2019-06-10 13:22:11
[2019-06-10 13:23:20] |
Above Post got updated.
[2019-06-10 17:08:18] |
You need to make sure that the Port numbers in Global Settings >> Data/Trade Service Settings >> SC Server Settings are different between these two instances. You do not have to check port numbers in the sub instances. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-06-10 17:08:35
