Date/Time: Sat, 18 May 2024 21:55:12 +0000
Unable to download 1921 update
View Count: 629
[2019-05-22 16:42:44] |
User545800 - Posts: 13 |
Keeps sending me in circles. Sent message log. Let me know.
[2019-05-22 17:26:37] |
The log does not show that you have made a request to update Sierra Chart. Here are the update instructions: Software Download: Fast Update Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-05-22 17:26:49
[2019-05-23 20:34:23] |
Have attached the screenshots of what happens. First when I login it says 1922 is available, then I select Help --> Download current version. I get the message on new version downloaded and SC needs to close. I click yes. No installer prompts come up. After sometime when I open SC, it again shows up as version 1919 only. Tried running installer per Fast Update section in Software Download with current version as 1922 and it resolved the issue. Please close this ticket.
Private File |
