Date/Time: Sun, 19 May 2024 20:36:45 +0000
problems connecting to live trading
View Count: 604
[2019-05-22 14:17:30] |
User221057 - Posts: 12 |
Good day. I'm having trouble connecting live trading.Not long ago I took a trial version of Sierra Chart and then paid for the package.My broker hooked me up to the stock exchange.The terminal has an account for live trading.The question is how to switch to live trading.Tell me please,where could not find a clear answer? Thanks for the early |
[2019-05-22 15:04:53] |
What Data or Trading service are you using or do you wish to use? See this page for the list: Supported Data and Trading Services: Supported Services Or, if you heard about Sierra Chart from a trading/broker service and want to use their service with Sierra Chart, tell us which one you were referred from. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-05-22 15:09:44] |
Thanks.Found the reason why it did not work
