Date/Time: Mon, 06 May 2024 07:52:40 +0000
connect Sierra witj IB
View Count: 1311
[2013-11-26 10:56:56] |
User67944 - Posts: 3 |
Hi, I tried to connect Sierra with TWS Interactive Brokers but itz doesn't work. I already set up API in TWS. I am running Sierra on Macbook with Pararells and Windows 8. I also tried on my old computer with Windows Vista and also doesnt work. Same problem. Thank you for your help. Software version: 872 | 2013-11-26 10:49:37 Current Service Package: 5 | 2013-11-26 10:49:37 Usage end date: 2013-12-08 | 2013-11-26 10:49:37 Sierra Chart Historical Data Service is included. | 2013-11-26 10:49:37 Active service: Interactive Brokers | 2013-11-26 10:49:37 Time zone: +00:00:00 (UTC+00) | 2013-11-26 10:49:37 Local computer clock: 2013-11-26 18:49:37 UTC: 2013-11-26 10:49:37 Time zone adjusted: 2013-11-26 10:49:37 | 2013-11-26 10:49:37 Program path: C:\SierraChart\ | 2013-11-26 10:49:37 Data Files path: C:\SierraChart\Data\ | 2013-11-26 10:49:37 OS Version Number: 6.2 | 2013-11-26 10:49:37 Connecting to data and trade server: localhost port 7496... | 2013-11-26 10:49:43 Failed to connect to the data and trade server. Winsock error: Error code 10061: No connection could be made because the target machine actively refused it. | 2013-11-26 10:49:44 Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2013-11-26 10:49:44 Error connecting to Data or Trading service. For help with this issue, press the Send For Analysis button on this window. | 2013-11-26 10:49:44 To prevent further connection attempts, select File >> Disconnect. | 2013-11-26 10:49:44 Disconnected from IB. | 2013-11-26 10:49:44 Will reconnect to the server in 5 seconds. Select File >> Disconnect to prevent further connection attempts. | 2013-11-26 10:49:44 Starting TWS auto-login thread. | 2013-11-26 10:49:47 TWS auto-login thread ending. | 2013-11-26 10:49:47 Connecting to data and trade server: localhost port 7496... | 2013-11-26 10:49:49 Failed to connect to the data and trade server. Winsock error: Error code 10061: No connection could be made because the target machine actively refused it. | 2013-11-26 10:49:50 Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2013-11-26 10:49:50 Error connecting to Data or Trading service. For help with this issue, press the Send For Analysis button on this window. | 2013-11-26 10:49:50 To prevent further connection attempts, select File >> Disconnect. | 2013-11-26 10:49:50 Disconnected from IB. | 2013-11-26 10:49:50 Will reconnect to the server in 5 seconds. Select File >> Disconnect to prevent further connection attempts. | 2013-11-26 10:49:50 Starting TWS auto-login thread. | 2013-11-26 10:49:51 TWS auto-login thread ending. | 2013-11-26 10:49:51 Starting TWS auto-login thread. | 2013-11-26 10:49:55 TWS auto-login thread ending. | 2013-11-26 10:49:55 Connecting to data and trade server: localhost port 7496... | 2013-11-26 10:49:55 Failed to connect to the data and trade server. Winsock error: Error code 10061: No connection could be made because the target machine actively refused it. | 2013-11-26 10:49:56 Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2013-11-26 10:49:56 Error connecting to Data or Trading service. For help with this issue, press the Send For Analysis button on this window. | 2013-11-26 10:49:56 To prevent further connection attempts, select File >> Disconnect. | 2013-11-26 10:49:56 Disconnected from IB. | 2013-11-26 10:49:56 Will reconnect to the server in 5 seconds. Select File >> Disconnect to prevent further connection attempts. | 2013-11-26 10:49:56 Starting TWS auto-login thread. | 2013-11-26 10:49:59 TWS auto-login thread ending. | 2013-11-26 10:49:59 |
[2013-11-27 04:00:45] |
Our only suggestion is to follow through the additional instructions at step 15 here: http://www.sierrachart.com/index.php?l=doc/IB.php#SetupInstructions Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2013-11-27 04:01:24
