Date/Time: Sun, 19 May 2024 13:25:06 +0000
Error loading C:\SierraChart\Data\VSA_Rel_Volume.dll. Windows error code 126: The specifie
View Count: 1680
[2019-05-21 19:56:04] |
User681249 - Posts: 5 |
Hi, I have transferred all files from Transact futures sierra charts, everything works fine, except one custom study from VSA Volume. This is what says in message log: CreateStudyDLLModuleFunctionObject Error loading C:\SierraChart\Data\VSA_Rel_Volume.dll. Windows error code 126: The specified module could not be found. Likely missing dependency file. | 2019-05-21 20:41:01.797 Same time this study works on transact futures sierra charts. Please advice. |
[2019-05-22 00:43:44] |
We are unable to help with studies that are not from Sierra Chart. You would need to contact the developer of that study and ask them for help.
