Date/Time: Sun, 05 May 2024 19:51:38 +0000
Cannot connect to IB API anymore
View Count: 1965
[2013-11-25 22:15:58] |
SoundsLikeSun - Posts: 30 |
Hi Sierra Team, Pretty worried, I updated all my Interactive Brokers software (Nov 13 version) but cannot connect to the API anymore. The report tells me I am using server version 67 and need 68 minimun. I checked the API Version, it says 9.70. Do you know what could be the problem ? Shall I check into the API cpp Server files ? Here is Sierra Chart Report Connecting to IB data and trade server: 127.0.0.1. Port 7496. | 2013-11-25 21:53:41 The network socket is connected. | 2013-11-25 21:53:41 Socket connected to TWS. Sending client version: 62. Waiting for acceptance. | 2013-11-25 21:53:41 TWS server version: 67 | 2013-11-25 21:53:41 IB: Trader Workstation 9392 or higher is required to connect. TWS server version required: 68 | 2013-11-25 21:53:41 Error connecting to Data or Trading service. For help with this issue, press the Send For Analysis button on this window. | 2013-11-25 21:53:41 Thank you for your help, Thomas |
Capture d’écran 2013-11-25 à 22.52.34.png / V - Attached On 2013-11-25 22:15:49 UTC - Size: 27.86 KB - 475 views |
[2013-11-25 22:40:32] |
Install the latest Trader Workstation with this link and you will be fine: https://download2.interactivebrokers.com/download/tws40_install_latest.exe Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2013-11-26 09:18:38] |
Great Thank you |
