Date/Time: Sun, 19 May 2024 15:52:34 +0000
Problems with Trail to Breakeven
View Count: 937
[2019-05-21 15:43:58] |
bfreis - Posts: 19 |
Hi, I'm having a problem with the "Trail to Breakeven" feature. After having properly configured a "Step 1" to "Trail to Breakeven", and verify that it works on, say, the ES, I'm having trouble when I trade the MES. Specifically, I have a Trade DOM configured like this: Symbol is ES and Trade and Current Quote Symbol is MES, with Use As Trade Only Symbol option checked. Is this supposed to work? If so, how? If not, could this be implemented? Thanks Date Time Of Last Edit: 2019-05-21 15:44:55
[2019-05-21 18:58:17] |
No this is not supported at this time with the configuration you are using but it will be in the next release coming out today or tomorrow.
