Date/Time: Sat, 27 Apr 2024 07:11:27 +0000
Multitime frames
View Count: 1159
[2013-11-25 21:11:05] |
stef2s - Posts: 1 |
Hello, i would like to know if it's possible to have multitime frames for the indicators in Sierra? and if it's not the case, is it possible to upgrade it? For example; I use Ichimoku and i want the 15m , 1H , 4h on the same chart. Thank you. |
[2013-11-27 04:03:52] |
We apologize for the delay. Refer to help topic 28 and see if that answers your question: http://www.sierrachart.com/index.php?l=doc/helpdetails28.html We are not completely clear as to what you are looking for. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
