Date/Time: Sun, 19 May 2024 16:36:24 +0000
IB
View Count: 655
[2019-05-19 23:50:27] |
User642012 - Posts: 51 |
hi can i conbect to interactive broker and trade through sierra chart ? And can i get accedd to HKFE live data by connecting ti IB? thanks |
[2019-05-20 14:10:05] |
Yes this is supported.: Interactive Brokers Trading Service The linked page has the set up instructions. You can use the HKFE data provided by Interactive Brokers. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-06-09 08:00:27] |
Terry Ko - Posts: 21 |
how about find symbols if I using Interactive Brokers? What code for HKFE live data from IB?
[2019-06-10 06:06:34] |
These are all listed in File >> Find Symbol when Sierra Chart is set to use Interactive Brokers. If you do not see a particular symbol listed, let us know.
