Date/Time: Mon, 20 May 2024 14:58:32 +0000
Volume at price colouring method
View Count: 1963
[2019-05-19 16:14:33] |
Dom7364 - Posts: 257 |
I have been reading through the Volume at price detailed explanation, and can't manage to find how to colour each volume at price bar within the volume profile, according to Dominant BID vas Ask, while having the lenght of each volume horizontal bar to display the total volume. I can do that and then display BID -ASK in figures, but how can you just colour the horizontal bar instead in either red/green/whatever else, according to the dominating aggressor?
[2019-05-20 10:21:23] |
Difficult question or obvious one?
[2019-05-20 10:27:27] |
User907968 - Posts: 804 |
This - Volume By Price Study: Volume Bar Calculation Method "Total Volume: This uses the Total Volume for the calculation of the length of the bars." & Volume By Price Study: Bid Volume and Ask Volume Coloring Method "Dominant Bid or Ask Volume Coloring - Full Bar: With this coloring method, the entire Volume bar is colored a single color that is either the Bid Volume Color or the Ask Volume Color, depending on which volume is greater." |
[2019-05-20 16:36:43] |
Yes the answer in post #3 is right and you may also be interested in this coloring method: Dominant Bid Or Ask Volume Coloring Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
