Date/Time: Sat, 18 May 2024 11:28:56 +0000
[User Discussion] - Pivot Points Calculation - Formula & Futures and/vs Stocks
View Count: 511
[2019-05-19 12:35:17] |
BrewTrader - Posts: 21 |
Hello everyone! Couple questions for the group, mostly opinion based I think. 1. Which "pivot points" formula type do you use for futures? Which way do you find most accurate? 2. For those of you using SC for stock trading too (not many I suspect), which formula type do you use? 3. For futures do you use the day session only or do you include "after hours" in your calculations? Which way do you find most accurate? 4. For those using SC for stocks, do you use after hours in your calculations? Which way do you find most accurate? I know I can backtest, and will probably do so...but looking for those with experience to give their opinion until I get around to the backtesting. Thanks, Randy |
