Date/Time: Sat, 18 May 2024 03:52:43 +0000
Recommend me a New PC upgrade to support 8 FHD monitors!
View Count: 636
[2019-05-19 08:49:22] |
User164231 - Posts: 278 |
Hi guys, I thought I was aggressive when I built my current PC (M910s Desktop (ThinkCentre) - Type 10MK , specs as attached). When doing manual back testing, it seems to run low on ram memory, took a long time to load and could only support up to 4 Full HD monitors. My questions; is it possible to add graphic card to support 8 Full HD monitors (or 4 x 4k) and ram to speed up the loading of data, or should I rebuild from scratch? Personally I try not to create more waste, but I don't know much about tech.... please advise. Thanks and good karma to everyone. Cheers. |
Current PC.jpg / V - Attached On 2019-05-19 08:37:11 UTC - Size: 33.58 KB - 270 views |
[2019-05-19 14:28:01] |
BrewTrader - Posts: 21 |
Recommend upgrading your ram, give yourself 32GB...big diff. Also, research if you'd benefit from a beefier processor (I run a Intel Core i7-7820X 8 core and am extremely happy), it will all depend on if the applications can benefit from the added cores. Also, I run an Nvidia P4000 quad output high end graphics card to push 4 full hd 4K monitors, you may be able to get 2 of those to push 8 monitors, but research first. Obvious question...do you run solid state drives? If not HIGHLY recommend upgrading. Suspect you do...but have to ask Good luck, Randy |
