Date/Time: Sun, 19 May 2024 17:52:11 +0000
[User Discussion] - Custom DLL unsupported in 1919, and cannot recompile.
View Count: 639
[2019-05-18 21:29:48] |
EdCarp - Posts: 25 |
I have a custom DLL that I wrote, it worked under 1918, but when I upgraded to 1919, SC says the version is unsupported. I tried downgrading to 1918, but my TransAct launcher still brings up 1919. When I tried to recompile the DLL under 1919, it says: c1xx: fatal error C1083: Cannot open source file: 'C:\SierraChart\SierraChartTransActMA\ACS_Source\HighVAP.cpp': No such file or directory When I go to that directory, the file HIGHVAP.cpp file is plainly visible. When I try to compile from the command line, the DLL is generated, but SC still says the DLL is unsupported. Date Time Of Last Edit: 2019-05-18 21:30:16
[2019-05-22 15:04:01] |
User180126 - Posts: 12 |
if you are still unable to roll back please contact support@transactfutures.com for information on how you can do that.
[2019-05-22 15:30:11] |
This was not previously answered because this is a technical impossibility: I have a custom DLL that I wrote, it worked under 1918, but when I upgraded to 1919, SC says the version is unsupported. I tried downgrading to 1918, but my TransAct launcher still brings up 1919.
We need to see the exact error message you are getting. Provide the Message Log showing this. c1xx: fatal error C1083: Cannot open source file: 'C:\SierraChart\SierraChartTransActMA\ACS_Source\HighVAP.cpp': No such file or directory Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-05-22 15:30:43
