Date/Time: Sun, 05 May 2024 01:29:27 +0000
Error with software update
View Count: 533
[2019-05-17 15:20:56] |
pa_trader - Posts: 29 |
I'm having difficulty with version update. I've sent the log to support. Could you please help me with this. thx |
[2019-05-17 22:54:38] |
When you send the Installer log you need to enter a name. Otherwise, we cannot identify it. Did you use a name and if so what was it?
