Date/Time: Mon, 06 May 2024 14:11:04 +0000
bar based back testing - contracts not flatten by the end of session
View Count: 518
[2019-05-17 14:48:35] |
User755537 - Posts: 15 |
Hello, I wanted to highlight an issue I encountered during back testing. When back testing using REPLAY, SC behaves as expected, i.e. as per conditions defined in the spreadsheet. However, when using rapid BAR BASED back test, SC does not flatten contracts at predefined time in the spreadsheet (while using REPLAY does). Is there a remedy to that? Kind regards, Roman Roszka |
[2019-05-17 22:40:04] |
How do you do a rapid bar based back test? The only degree of speed control is with the Chart Update Interval and we do not see how that matters. And what are you doing to cause a flattening of the Trade Position? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
