Date/Time: Fri, 03 May 2024 07:56:49 +0000
Got Buy Exit while cells $L$3 & $J$29 have False Values
View Count: 1135
[2013-11-25 16:06:18] |
ezfcharts00049 - Posts: 15 |
I am using Sierra chart Ver 1051. When replaying ESZ3 (day: Nov. 8th, 08:31-08:45 )I got exit to long position although both $L$3 & $J$29 had False values. I replayed & watched it carefully many times at Speed of 2 tick (at Accurate Test Mode) but allway got the same results. the cells in column J looked quite OK is there any other case in which exit is forced? please advise thanks H. Oren |
[2013-11-25 16:55:35] |
Look at the Trade >> Trade Activity Log: http://www.sierrachart.com/index.php?l=doc/doc_TradeActivityLog.php It will clearly indicate the source of the exit order. The exit cell could briefly go to TRUE and you just do not see it. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
