Date/Time: Wed, 01 May 2024 23:16:48 +0000
[Programming Help] - Trade Window Showing Inaccurate P/L
View Count: 604
[2019-05-16 19:39:34] |
tesseract353 - Posts: 66 |
In Chart Settings, Symbol is set to ES.20190600.CME_Eq and Trade and Current Quote Symbol is set to MES.20190600.CME_Eq. Use As Trade Only Symbol is not selected. When a trade is taken in this chart, the attached Trade Window P/L is showing the tick value as $12.50 instead of $1.25. Same for Trade Window DlyPL. Attached Trade Window in DOM that is set to MES.20190600.CME_Eq does accurately show tick value as $1.25. Please advise. |
[2019-05-17 22:59:38] |
You can change the Currency Value per Tick to what you require: Chart Settings: Currency Value Per Tick (Chart >> Chart Settings >> Symbol >> Symbol Settings menu) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
