Date/Time: Thu, 02 May 2024 17:28:38 +0000
DOM Static price ladder on
View Count: 2105
[2019-05-12 23:16:34] |
User116783 - Posts: 84 |
Hi, How do you keep the trade DOM price ladder from shifting up or down when the highlighted last price moves out outside of the predefined range? Thx, ZS |
[2019-05-13 01:06:46] |
There really is not a way to do exactly what you want. Do you want to keep the last trade price completely stationary? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-05-13 01:08:00
[2019-05-13 01:23:37] |
I would like to keep my DOM bracket orders stationary. Unless I manually move them up or down. As it is, when markets start moving fast, the price ladder will shift up and down. Which in turn causes the bracket orders to move. ZS Date Time Of Last Edit: 2019-05-13 01:25:29
[2019-05-15 01:56:15] |
Lets say the visible range on my DOM is 8097.5 - 8075.0. I place a bracket order to BUY at 8085 which I want to keep watching. Then the highlighted last price moves above 8097.0 which causes my bracket order to begin shifting. Which is really irritating. There must be a way to make the view-able range static to prevent it from moving. And if this isn't an option, it's something you should definitely consider implementing. ZS Date Time Of Last Edit: 2019-05-15 01:58:48
[2019-05-15 15:34:38] |
John - SC Support - Posts: 31324 |
Follow the directions here to set the Price Ladder static: Chart Scale and Scale Adjusting: Using Fixed Values for Top and Bottom of Scale Range For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-06-20 17:50:20] |
With user defined settings for the Trade DOM range, how do I change the values for the top and bottom? Currently the highest I can scroll is 9368.5 and lowest is 9279. A range of 89.5. I would like to widen this range as much as possible. ZS |
[2019-06-20 19:29:43] |
Ok, I've answered my own question. Which was how to emulate the NT static-superdom with SC's Trade DOM. The solution was to set the DOM to interactive scale move and scale range: constant range. Then under scale settings set constant range scale mode to manual mode. These settings prevent the price ladder from shifting up and down while also not constricting the last price to a predefined range. ZS Date Time Of Last Edit: 2019-06-20 19:32:34
[2019-06-22 03:09:02] |
This is good.
