Date/Time: Fri, 03 May 2024 10:48:20 +0000
Delta Value Chart
View Count: 2123
[2013-04-10 14:00:06] |
User16629 - Posts: 3 |
the delta value chart in the "settings and inputs" allows one period input value not the max min value as well, I have tried Reset Defaults , but no change, how do I get the chart updated?
[2013-04-10 17:01:17] |
This does not sound like a study developed by us. What is the exact name of the study?
[2013-04-10 19:18:36] |
OOOOOps, sorry , its the "Value Chart"
[2013-04-10 19:36:21] |
We are not clear exactly what the question is.
[2013-04-15 07:53:14] |
my value chart in the settings and inputs window, allows for a single period change, in a friends value chart it has the options as follows, period, Moderately Overbought level and Significantly overbought level , I do not have the last two option?
[2013-04-15 08:09:51] |
Please update by selecting Help >> Download Current Version from within Sierra Chart.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2013-04-15 08:10:06
