Date/Time: Sat, 04 May 2024 14:49:04 +0000
orders, position and activity Log during Sim tradinf
View Count: 1226
[2013-11-23 12:19:36] |
faheem999 - Posts: 1 |
Hi, I'm using SC for sim trading. After setting every thing as per the documentation, and opening a position, it does not appear in the "trade orders and positions" window. After closing the position the trade activity log is empty!! This is in on "replay chart mode" Is there something I'm missing I'm on the free trial now Best regards Date Time Of Last Edit: 2013-11-23 12:32:28
[2013-11-25 03:53:49] |
The simulated Positions will only be on the Trade Stats for Charts tab: http://www.sierrachart.com/index.php?l=doc/doc_TradeStatusWindows.html#ChartTradeStatsTab You must not have a setting correct at the top of the Trade Activity Log. Refer here to the step-by-step instructions: http://www.sierrachart.com/index.php?l=doc/doc_TradeActivityLog.php Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
