Date/Time: Wed, 15 May 2024 22:55:49 +0000
Limiting historical market depth data files
View Count: 1187
[2019-04-30 07:34:23] |
User465507 - Posts: 74 |
I'm using the 'Market Depth Historical Graph' indicator which records the depth of a product for visual display. I'm finding my Sierra records non-stop when all I really need is the past 3 days at most. How do I change this instead of manually deleting the depth files each time? In my 'Data/Trade Service Settings' I've set 'Max Historical Intraday Days to Download', '1-Tick Data' to 4. I need 1-min data going back historically quite far, it's just the depth that I don't need going back that far... Any ideas? |
[2019-04-30 12:37:45] |
User138602 - Posts: 169 |
should be main chart settings - 1st tab
Date Time Of Last Edit: 2019-04-30 12:38:22
[2019-04-30 12:48:16] |
This is controlled with this particular setting: Chart Settings: Maximum Market Depth Data Days to Load (Chart >> Chart Settings >> Market Depth menu) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
