Date/Time: Thu, 16 May 2024 19:27:10 +0000
Which order types can I keep at DTC server?
View Count: 895
[2019-04-28 12:15:11] |
ARDAN - Posts: 66 |
I am configuring a DTC server environment. So the clients will be connected to the DTC server of mine and It is connected to LMAX. (Server side OCO and bracket orders are disabled in my own DTC server to bypass SC's DTC server) I would like to keep my stop and target orders in my DTC server without submitting them to LMAX. -The regular stop, the limit and MIT order is sent to exchange immediately. -Stop with the Last Triggering, Stop with Bid/Ask Triggering, MIT client orders are kept at the client. I would like to learn If there is a way to keep my stop and target orders at my DTC server without submitting them to exchange. Thanks Date Time Of Last Edit: 2019-04-29 15:32:29
[2019-04-30 03:20:21] |
Here is another order type to be aware of: Order Types: Limit if Touched - Client If the DTC server is Sierra Chart, then there is not a solution to this. Either the orders are going to be on the client side or they will be sent through all the way to the final destination. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-04-30 03:20:27
