Date/Time: Sat, 27 Apr 2024 12:01:26 +0000
[Programming Help] - Alert for Total Volume in Numbers Bars Calculated Values
View Count: 2260
[2019-04-27 00:18:20] |
WRBishop - Posts: 6 |
Is there a way to have an alert when the Total Volume for the current bar surpasses a % of the Total Volume of the previous bar? In the image attached I would have that 58314 alert and change background color or char color or anything if possible. Thank you in advance.
Capture.PNG / V - Attached On 2019-04-27 00:15:43 UTC - Size: 131.28 KB - 1181 views Attachment Deleted. |
[2019-04-27 01:02:03] |
To do this, use the Color Background Based on Alert Condition study: Color Bar Based on Alert Condition That study can make reference to the Numbers Bars Calculated Values study Subgraphs. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-04-27 01:14:12] |
Thank you. Any chance you all can write the alert condition for me? I am afraid I could spend all weekend and still have no clue. If not I can ask around. Thanks again.
[2019-04-27 11:43:16] |
Ackin - Posts: 1865 |
Compare volume only prior bar or more bars back?
Date Time Of Last Edit: 2020-06-24 22:21:22
[2019-04-27 13:06:52] |
I was actually looking to see if the Numbers Bar Calculated Value field itself could highlight. So in my image above the 58314 would highlight as soon as it reaches or gets above say 300% the previous volume. I will check this out too, thank you. |
[2019-04-27 13:27:30] |
I am an idiot never mind.... this is already built into the study. Should have known SC already thought of it. Sorry for the trouble.
Capture.PNG / V - Attached On 2019-04-27 13:27:24 UTC - Size: 57.04 KB - 526 views |
[2019-04-29 01:16:54] |
User103219 - Posts: 8 |
OK so not figuring this out. The study above from Ackin seems to be what I am looking for but I cannot find it. I am looking for the following: Numbers Bars Calculated Values: When Current Bar Total Volume is 400% >= Previous Bar Total Volume Highlight Background Red I thought the NBCV study accomplished this but it does not. I have tried the suggested Color Background Based on Alert Condition but cannot get it to trigger at all. If this is not possible I would gladly take an alert that colors the entire Numbers Bar based on the same condition. Any help would be greatly appreciated. Date Time Of Last Edit: 2019-04-29 01:25:23
[2019-05-04 17:00:20] |
Hi, Study "Volume percent from prior bar" contact link: https://www.sierrachart.com/UserControlPanel.php?page=StudyStore&SCDLLName=zyp_download_free Date Time Of Last Edit: 2020-06-24 22:22:35
