Date/Time: Thu, 09 May 2024 01:25:19 +0000
Time Line Display in 1050 Non-.NET
View Count: 1204
[2013-11-22 14:47:36] |
Glyn - Posts: 20 |
Time Lines are corrupted in version 1050 Non-NET, where it is now impossible to change the default display settings.
[2013-11-27 09:23:30] |
Glyn - Posts: 20 |
Support: Can you indicate whether you will correct this limitation in a future release? Currently, draw styles are disabled so that it is impossible to select e.g a color bar or point on high/low to display the alert. With multiple alerts on a chart the new default of a vertical line becomes distracting, to the point of being unusable. I think this change may have crept in when a third field (Custom Text) was introduced to the study. Your input to restore the functionality of this very useful tool would be much appreciated. |
[2013-11-28 07:10:44] |
We are looking into this now to see what can be done.
[2013-11-30 15:55:22] |
Glyn - Posts: 20 |
The good news is that version 1055 now allows Color Bar options to be selected; the bad news is that Point on Low/High draws points on every bar in the chart, not just the selected time line bar.
[2013-12-01 00:45:40] |
This will be resolved in the next release.
