Date/Time: Fri, 03 May 2024 01:36:02 +0000
(Question / Feature Request) Trade Service - Communication with a TradingBot via localAPI
View Count: 972
[2019-04-25 18:25:32] |
Hiromatsu - Posts: 1 |
Dear Sir or Madame, let me start with saying sorry for not being a native speaker. Hopefully I can phrase my question / problem in understandable way. I am absolutely new to Sierra Chart and I came over from TradingView Pro+. I saw your BitMex trading integration and found it really cool. As I am trading on Deribit I searched your forums and from what I understood a Deribit integration is not planed. So I was asking myself if there are any plans on implementing a possibility to use local api to connect to a trading software. (Perhaps there is already a possibility and I just did not find out how to do it) To be precise: I have a crypto trading bot (Haas online - Haas Trading Server) This software could execute trades via a local api connection: (Documentation: https://haasome-tools.github.io/haasomeapi/) So what I would love to do is send a api command to the local api interface of the trading bot, whenever my trading strategy triggers a signal in Sierra Chart... So Signal Triggers and Sierra Chart sends a predefined api command to trigger order execution in the crypto trading bot... Thank you very much. Kind Regards Hiromatsu |
[2019-04-26 04:59:13] |
You could try to do this using ACSIL which utilizes C++, to communicate with your other API. Refer to: https://www.sierrachart.com/index.php?page=doc/Contents.php#AdvancedCustomStudySystemInterfaceandLanguage Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
