Date/Time: Sat, 04 May 2024 02:10:55 +0000
data delete and download using ACSIL
View Count: 655
[2019-04-25 18:09:12] |
dtl-saw - Posts: 79 |
Is there a function in ACSIL that can delete symbol data starting from a specific date and time. I'm looking for similar behavior as when using the chart shortcut menu item "delete and download data" button. What that button does is delete data from the point in the chart that I right clicked on to get the chart shortcut menu to appear. Is there a function or combination of functions in ACSIL that I can use to accomplish this same task from within my study? By the way, I don't want to delete all the data for the symbol but instead just from a certain date and time. thanks |
[2019-04-26 05:07:20] |
Yes. Refer to: sc.StartDownloadHistoricalData() Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
