Date/Time: Tue, 07 May 2024 22:06:48 +0000
Use different Rithmic-Account in Sub-Instance than in Main-Instance
View Count: 748
[2019-04-25 16:28:17] |
User674948 - Posts: 3 |
Is it possible to use a different Rithmic-Account/-Login in a Sub-Instance than I use in the main-instance? I tried this by choosing „Rithmic Trading [trading]“ and logging in to the other Rithmic-Account in the sub-instance, but that didn´t work (the error „Service Connection Error: Connection error messsage from service: Rithmic Trading / Error running DTC server program“ comes up). Ultimately I´d like to use a different trading-account (Sub-account at AMP) in the main-instance than in the sub-instance. Is this even possible? If that doesn´t work, it means that I need a second Sierra-Chart-Account to trade with my AMP-sub-account, right? Kind regards. |
[2019-04-26 04:55:39] |
Yes you can. Just install a completely independent instance of Sierra Chart: Using Multiple Data and Trading Services at the Same Time Do not use a sub instance. Ultimately I´d like to use a different trading-account (Sub-account at AMP) in the main-instance than in the sub-instance. Is this even possible? Basic Trading and the Trade Window: Main/C >> Trade Account (Selecting Trade Account for Chart / Trade DOM) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-04-26 04:55:49
