Date/Time: Tue, 07 May 2024 09:01:39 +0000
Time and sales bid and ask records colors
View Count: 1313
[2019-04-25 15:15:01] |
trader1 - Posts: 128 |
Hi, I would like to change the background on the bid and ask records in the time and sales window. I have attached two screenshots of the colors I have and the settings I am trying to change them with. I want to have a black background on the bid and ask records, but I have a gray background. Can you please tell me how to change it? Thanks. |
SierraChart bid ask background_02.png / V - Attached On 2019-04-25 15:13:08 UTC - Size: 28.1 KB - 254 views Attachment Deleted. SierraChart bid ask background_01.png / V - Attached On 2019-04-25 15:13:25 UTC - Size: 24.45 KB - 268 views |
[2019-04-25 16:02:24] |
John - SC Support - Posts: 31419 |
It looks like you probably have Chart specific Graphics Settings, therefore you would need to change that particular setting within the Graphics Settings for the chart. You find that under Chart >> Graphics Settings - Chart. If this is the case, then when you select that option and the window opens, you will not have a checkmark next to the item at the top that reads Use Global Settings Instead of These Settings. You will find the documentation regarding this setting here: Graphics Settings: Use Global Graphics Settings Instead of These Settings For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
