Date/Time: Tue, 07 May 2024 11:12:01 +0000
Adding Commission to BITMEX feed
View Count: 611
[2019-04-25 14:56:27] |
Theseus - Posts: 6 |
Hello, i dont know why in my backtests the commissions are not displayed. Bitmex marketmaker = 0.075% per trade So i have to add by global settings => symbols => @bitmex the 0,075% at use global round commission right? thank you very much in advance |
[2019-04-25 18:53:01] |
You cannot use a percentage for the Global Round Turn Commission setting. It is a per contract value. And where you looking to see the commission? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
