Date/Time: Sun, 05 May 2024 04:27:06 +0000
[User Discussion] - Time display on main price graph
View Count: 1201
[2013-11-22 13:03:22] |
Davidside - Posts: 16 |
Is it possible to display time (same time as it is on chart header) on main price graph? Similarly works countdown timer studie, but it is for TR. Thank you. |
[2013-11-30 13:48:30] |
Can someone help me with this?
[2013-11-30 22:00:05] |
This is not supported.
[2013-11-30 23:48:01] |
Sawtooth - Posts: 3993 |
There is a Clock study in the User Contributed Studies, but it doesn't work well with some timezone settings. Analysis >> Studies >> Add Custom Study >> User Contributed Studies >> Clock |
[2013-12-01 11:48:40] |
It works just as I need. Thank you very much.
