Date/Time: Sun, 28 Apr 2024 07:54:10 +0000
markers not staying in place on chart
View Count: 595
[2019-04-24 21:01:40] |
sierra - Posts: 22 |
My name is Kurt and I am having issues with placing markers on charts. I mark High 1/ Low 1 on charts with the marker tools. When I turn off the computer at night and restart Sierra Chart the next day I find the markers on incorrect bars, usually they end up all one bar to left. This causes me to have to go back and remark all bars from previous day. The chart I run is a 2000 volume chart and I have reviewed in detail all the chart settings you require for using volume charts. Please advise what I am doing wrong. This only happens one out of every 15 days or so, but it causes many problems when it happens. Thanks for you help. Kurt |
[2019-04-25 09:50:46] |
We think you probably do not have New Bar at Session Start enabled: Chart Settings: New Bar at Session Start (Chart >> Chart Settings >> Session Times >> Intraday Chart Session Times menu) You are going to need to enable that to avoid this problem. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
