Date/Time: Sun, 05 May 2024 12:56:52 +0000
Main window child tabs v1908
View Count: 866
[2019-04-23 17:34:57] |
User977098 - Posts: 28 |
Hello, I am aware you are currently working on some problems regarding this so maybe my problem will soon not be relevant. I have a chartbook with three child windows. Before updating to the latest version (1908) I was able to hide the main window and then tile the remaining two windows vertically and then simply double click on the main window to bring it back to the front. This is no longer possible. Double clicking on the main window no longer brings it back to the front, to do this I need to go window > Restore. Even this for some reason only brings the main window onto half the screen (as if it was a part of the tiled scenario). What was once an easy process has become rather cumbersome, not a big deal if it only is needed to be performed a couple of times a day, but when I need to do this multiple times an hour it becomes less than ideal. I have performed a reset both the windows and the child windows. |
[2019-04-23 18:42:58] |
Work is still being done on the window tabs. We will make sure the functionality is as it was before.
