Date/Time: Sun, 28 Apr 2024 00:04:47 +0000
Access drawing alerts via ASCIL
View Count: 609
[2019-04-23 11:24:58] |
User907968 - Posts: 802 |
Hi Support, as per the title, is it possible to access/set drawing alerts from ASCIL? I did try to search this, but found no information, so maybe it is not supported. Thanks |
[2019-04-23 18:32:22] |
No, this is not supported.
