Date/Time: Sat, 27 Apr 2024 18:15:27 +0000
Function Draw volume profile disabled
View Count: 2249
[2013-03-21 12:20:50] |
User81127 - Posts: 15 |
Hi, I use SC level 3,and I cannot draw a volume profile into the chart. Please see the attached screen. Coul you advice what might be wrong please? My version is 956. Thank you. Jiri |
Attachment Deleted. volume profile.jpg / V - Attached On 2013-03-21 12:18:57 UTC - Size: 188.65 KB - 846 views Attachment Deleted. |
[2013-03-21 16:23:47] |
This requires Sierra Chart package 5. To change your Sierra Chart service package, select "Help >> Purchase / Account Management" on the Sierra Chart program menu. On the displayed webpage, click on "Change Service Package".
The remaining service usage time on your account will be adjusted based upon the cost of the package you are changing to. If the new package is a higher-priced package, then the usage time will be reduced due to the higher price. There is no charge for changing your Sierra Chart service package. Only your usage time is adjusted. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
