Date/Time: Sat, 04 May 2024 20:39:24 +0000
Third Try: Watchlist and symbol drawings disappearing. Thanks in Advance.
View Count: 1181
[2013-11-22 00:44:43] |
reggytrades - Posts: 29 |
Is it possible to use a watchlist to cycle through about 20 symbols while keeping the symbol drawing on each symbol chart? I have Global Symbol Setting updated for each symbol but when cycling through the watchlist, each symbol will not retain its drawings. Is there any documentation, or any function available to maintain the Global Symbol Settings for the symbol "drawings". As far as I can see there is no dialogues or menus anywhere to retain the Global Symbol Settings for the drawings, but only for the price formats.
[2013-11-22 01:00:57] |
Based upon how you explained what you actually want to do in your other posting, the answer is no.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2013-11-22 01:01:15
